Turbo removal
Posted 18 April 2022 - 08:33 PM
What’s the correct easiest way to remove standard turbo from engine bay process
for refurb or upgrade
Posted 19 April 2022 - 09:07 PM
I guess it depends if doing yourself or a garage. I saw on the net a company do an engine & gearbox out, fit a turbo and back in within 4 hours. I’m sure if it was Audi they would call it an 8 hour job at whatever their extortionate rates are currently.
Posted 19 May 2022 - 08:08 PM
Edited by Rantnrave, 19 May 2022 - 08:09 PM.
Posted 20 May 2022 - 12:04 AM
Ended up dropping sub frame on a car ramp wouldn’t attempt on anything else as would be near on impossible & very time consuming the main issue is the manifold bolt access other than that dropped the prop & exhaust obviously disconnected steering column inside car then wasn’t too much of a problem
Well at least you managed to get the job done. Did you go for a standard or upgraded turbo in the end?
Posted 20 May 2022 - 12:29 AM
Posted 20 May 2022 - 08:02 AM
Hybrid 550 unit need to sort mapping now rang mrc & was told they don’t do the 8p anymore
If you've fitted a TTE turbo try Ben @ ttu for a custom remap as his very experience with 8Ps & 8Vs.
Btw my 8P has been remapped with wmi by Ben
Posted 23 May 2022 - 05:34 AM
Thank you for recommending us Dell, but I won't get involved in tuning the 8p unless it's our hybrid turbo fitted.
Posted 23 May 2022 - 11:39 AM
But thanks
Posted 23 May 2022 - 06:16 PM
We tune this engine weekly on stage 3, we only tune them on our own hybrid turbocharger due to spending 2 years designing the turbo to perfection on my own personal vehicle.
Hybrids are great and all but wrong size components can create heat, lag or even just don't work if not done correctly.
We do a drive in drive out service, supply on exchange, fit and tune for £3800 with no obligation 12month warranty
Posted 23 May 2022 - 06:19 PM
Edited by Rantnrave, 23 May 2022 - 06:19 PM.
Posted 23 May 2022 - 08:28 PM
Posted 23 May 2022 - 08:34 PM
Posted 23 May 2022 - 08:53 PM
What turbo did you go for if you don't mind me asking?
Posted 23 May 2022 - 08:56 PM
Posted 23 May 2022 - 09:14 PM
Posted 26 May 2022 - 07:10 PM
Posted 26 May 2022 - 08:07 PM
No worries thanks for the input but have other things I’m also trying to source such as the superseded injectors for the 8p apparently the the 8v ones & who supplies them
You can get the "L" Spec injector's from a main dear or as I did from my local TPS.
Hope your sitting down as they are probably over £800 for the set since I bought mine a few years back.
You wouldn't need new "O" rings or the plastic bottom seal as they are already fitted on the new injectors,will need new holding elements tho.
Some TPS wouldn't deal with the public so you may need to get someone you know who has an account to get them for you.
Posted 26 May 2022 - 08:10 PM
Is there a part number associated with these
Posted 27 May 2022 - 10:47 AM
Thanks for the info
Posted 27 May 2022 - 07:11 PM
Good guy.
