Guide for door card removal?
6 replies to this topic
Seb_RS3
Seb_RS3
  • 412 posts
  • LocationHeysham
Is there any good guides out there for removing the door cards on the 8P RS3?
YouTube seems to be full of newer RS3 guides and some standard A3 8P ones. (Are they close enough?)
Cheers.
Cheers.
The door cards are no different to any other A3 8P mate.
Seb_RS3
Seb_RS3
  • 412 posts
  • LocationHeysham
Ah that's good to know. I've seen A3 guides for other bits and found extra fixing etc.
Just need to get a plastic trim tool now.
Cheers Dell.
Cheers Dell.
https://www.ebay.co....kp:BFBMivrC7fhf
Seb_RS3
Seb_RS3
  • 412 posts
  • LocationHeysham
Seems cheap enough haha. I'll give them a shot. Sounds like I have a loose screw behind the panel and it's driving me nuts buzzing away while driving.
I feel you in that because there is nothing worse than an annoying buzz or rattle. At least you know where it is coming from.
The door cards are easy mate. The fronts have 4 torx bolts (1 at the base of the door by puddle lights, 1 above the pocket, 1 by the window switch (trim needs popping off & 1 above the handle (trim needs popping off).
Then prise from the bottom till 1 lug unclips so you can get your hands in and give it a yank, doesn’t sound the best but it’s what you need to do.
Then disconnect electrical harness connector from the door, remove the door handle hook and away she comes.
