Posted 11 February 2022 - 07:27 PM
I was something like ‘unable to connect to interface’ ‘-1’
Then said use settings to test. But when I went to test it it’s still saying unable to connect to interface
Posted 11 February 2022 - 07:39 PM
Posted 12 February 2022 - 11:02 AM
Only one that stands out is
P0343 - camshaft position sensor - signal too high
I can hear the fuel pump priming so that would suggest that is good and now I’m gunna pull the sparks to see how they look. I would hope the garage would have checked this but gotta be worth a check myself
Posted 12 February 2022 - 11:05 AM
Posted 12 February 2022 - 11:17 AM
Posted 12 February 2022 - 01:05 PM
Read that these mainly don’t throw faults unless the car is running which at the moment mine isn’t but could stop it as the ecu doesn’t know what position the engine is in to fire.
For the sake of £30 For a camshaft sensor which I have found from europarts I might aswell change it.
Anyone had similar issue with these or know if I’m wrong and it’s a crankshaft sensor I need and where the crankshaft sensor is located?
Edited by Stupher10, 12 February 2022 - 01:38 PM.
Posted 12 February 2022 - 03:06 PM
It has both camshaft and crankshaft sensors.For the unknown faults have you tried the Ross Tech website.They should know after all they make the VCDS.
Posted 12 February 2022 - 05:13 PM
Posted 12 February 2022 - 05:19 PM
Posted 12 February 2022 - 06:30 PM
Raptor I’ve tried Ross-tech wiki but the issue is that VCDS isn’t giving me an error code to search for when I put in 10678 / 10680 they’re not recognised as fault codes? I think that’s a red herring to be honest anyway as I can’t see why that would stop the car starting.
Has the ECU been property coded as it's paired to the immobiliser in the clock binnacle ?
Posted 12 February 2022 - 07:31 PM
Posted 13 February 2022 - 09:39 AM
Had a crank sensor go on my old 2010 Black Edition S3. For a while it would take longer to crank then catch and start, sometimes I could reset with vcds.
then it failed completely, vcds could not reset, , and it was game over, that car wa going no where, it had to be winched out of my garage and recovered,
was about £120 - £150 quid job if I remember correctly, fiddly, and under or behind something to access, but that was a 2.0l 4 cylinder TFSI .
Posted 13 February 2022 - 10:00 AM
Whilst I’m at it I’m going to replace the spark plugs.
Does anyone know what size socket I require to remove them, thought mine would fit but think it’s too small.
Posted 13 February 2022 - 02:20 PM
Cheers Paul. I have both sensors on order so hopefully they might solve the issue.
18mm if my memory serves me correct or check what size when you get the plugs.
Posted 13 February 2022 - 02:30 PM
I’m hoping that by some miracle a combo of sensors and plugs might get her to fire up.
Posted 13 February 2022 - 09:53 PM
Posted 15 February 2022 - 05:00 PM
Hello
Send both ecu to the turbo unit ltd our address is on Google or our website.
Please attach your name and contact number with your return address.
Hi Ben,
Thank you for this offer but for now it shouldn’t be needed. I have opened a case through eBay for a refund of the dodgey ECU, as since then I managed to get hold of another ECU and that cloned without issue.
Only issue is still that the car won’t start but believe that has nothing to do with to ECU at this point.
Does anyone know what the car looks for on a start up procedure?
Posted 16 February 2022 - 12:49 PM
The very thing I did was check the ignition system fuse and on the meter it tested fine. Was working on it again today and thought I’d recheck the fuses and again it tested fine on the meter. I think noticed some very small carbon build up on the spade. Put my meter on that and nothing! As you can see by the pic below.
I then swapped this fuse with the on for the windscreen wipers and there you go car fires up first time without hesitation!
Can’t believe the car has been off the road for over a month and spent 3 of those weeks in specialist garage and the culprit looks to be a bad connection on 50p fuse!
I am obviously happy that the car runs by my god this has been stressful.
Thanks again for the input and advice from you guys it has definitely helped me through the process of elimination.
Posted 16 February 2022 - 01:50 PM
Quite a common fault with the fuse fracturing & sending you up the garden path as I've had it myself with the HVAC on my old A3 3.2.
Glad you got to the bottom of it eventually 👍
Edited by RS3Dell, 16 February 2022 - 02:33 PM.
Posted 16 February 2022 - 03:16 PM
Only downside for me is spent a fortune on an ecu and getting it programmed which I probably didn’t need but ohwell. Aslong as I can get the cash back from the duff one that I got sent when I challenge it with ebay then I can suck up the other costs haha
Also tagged with one or more of these keywords: ECU, Wont start
MK2 RS3 8V Chassis →
Tuning and Modifications →
Revo RS3Started by 445, 16 Nov 2015 ![]() |
