P2178 fault code looking for ideas.
Posted 12 July 2021 - 04:03 PM
Sorry for the long post but trying to get as much info surrounding the lead up to the code as possible.
My car was on the rolling road on Thursday and as I’ve suspected for a while it had a pretty crap map on it. Was putting out 385hp and 581Nm. Car was flashed with MRC software but was pulling timing with Shell Nitro, having a suspicion it was a bad batch from a small garage I used, octane booster added to see if it was in fact bad fuel, which it was as the octane booster helped.
Anyway I’ve driven the car about 10 times since getting the new map and at least 4-5 times I’ve got the above code, system too rich off idle. The tank of Shell Nitro and octane was ran down to quarter in the process and filled back up with Momentum. I’ve logged the car and it’s only pulling 1.5 degree of timing from time to time on a 2nd to 3rd gear pull to redline.
The code always seem to trigger around 1700-1800 rpm looking at my VCDS scans. I’m guessing that’s just the specified criteria for it to trigger. Just had a play around and when watching the advance measuring values it seems to misfire when you hold the revs anywhere between 1000 and 2000 rpm. Anything above or below that and no misfires. For the too rich code I started to think injectors but changed the plugs prior to getting the car mapped and cylinders 2-4 had pure white ceramic on the tips and 1 had a very slight black colouration on the ceramic. I know with this map pushing things that but harder than the previous one any issue will be highlighted so I took them out last night again to see if there was anything glaringly obvious but of course the octane booster had given them a brown colour. So cleaned them up and refitted. I’ll check them later for any signs of sooting.
My initial though was maybe it’s the octane booster causing the code but then again it’s not creating a richer AFR just increasing octane and knock suppression. I don’t want to drive the car if I’m risking bore wash with too much fuel going into a cylinder or cylinders.
So on short I’m not sure if it’s maybe just needing a map tweek or pointing towards something else like injectors failing.
Posted 12 July 2021 - 07:48 PM
Tuner is on holiday till next week so looking to try and get some guidance in the mean time on my issue.
100% I’d wait to speak to the tuner and see what they are suggesting.
Posted 13 July 2021 - 05:10 PM
Posted 13 July 2021 - 05:13 PM
Posted 15 July 2021 - 08:01 PM
Has this car had injectors?
Boost leak- fault would be under or over boost or malfunction fault for n75.
Lambda can be logged, but tends to throw a fault if it has an issue.
Posted 18 July 2021 - 10:24 AM
So is the sw mrc or some 1 else?
Yeah it’s MRC stage 1 now. I was thinking any of the issues would surely trigger a code of their own.
I’ve logged the lambda and it seems to be working fine. Hovering either side of 1. I’ve yet to log it when the fault triggers though, not that it will make much difference.
I started the car today with the fault present and the car was running very ruff and kept stalling out after 5 seconds, could smell fuel. I’ve started it previously with the code present and it would start ok. Cleared the code and it ran fine again for the cold start and when the revs dropped. Stupidly never logged the car while it was running ruff. I guess it was running rich though or maybe the injectors leaked down I over night and the excess fuel was burnt off the third time o started the car?
Not done injectors on this one but I’m thinking it’s a wise move to do them.
Posted 18 July 2021 - 11:05 AM
Mark.
Check the engine temperature sensor is not causing an issue.
With a cold engine I would expect to see the water showing round about ambient temperature.
Then watch it while the engine warms up to see any abnormal behaviour till fully hot @ 90'
Posted 19 July 2021 - 10:04 PM
Lambda specified is nearly always 1 and actual value fluctuates either side of 1 as no doubt it should. Manifold pressure specified and actual seem to be within 0.1 Kpa of each other. HP fuel specified and actual track each other very closely as well. Long term fuel trims were around -5.5% last drive and -3.8% the time before. Car doesn’t pull timing much on full throttle pulls, when it does it’s 1.5* up to 2.3* and it seems to be worst around 1000-2500rpm partial throttle I’m seeing up to 4.5* at times. Could well be crap fuel again, I’ll try to fill the tank at another garage and log timing pull, if it’s no good I’ll try octane booster again to see if it helps. Also took the NGK plugs back out and put the stock ones back. I started the car earlier today and got fault codes for multiple cylinder misfire and codes stored for cylinder 2 and 5 specifically.
Car definitely hesitates regardless of what plugs are in it when pulling off just before 1000rpm and quite often at partial throttle in 3rd or 4th till you get past 2000rpm. Lambda actual seems to dip right down to .7 odd when it happens for a split second when I first press the throttle then it recovers.
Posted 02 August 2021 - 11:25 AM
Posted 02 September 2021 - 03:48 PM
