Rear Brake Upgrade
Posted 28 May 2020 - 02:29 PM
What’s everyone running? Can anyone recommend anything?
Posted 28 May 2020 - 04:29 PM
Not sure there is that much point - the rear brakes arn't really doing that much compared to the 8 pot fronts.
Posted 28 May 2020 - 04:46 PM
Edited by StephenG, 28 May 2020 - 04:47 PM.
Posted 28 May 2020 - 05:37 PM
Soon will be time to replace the rear brakes, I have seen some people have upgraded them to bigger discs etc.
I was a frim believer & posted such in the past that bigger rears wasn't beneficial, but since fitting the Reyland 350mm I now back pedaling on that statement.
As Stephen has preempted me.....the RS does brake flatter with not so much weight transfer onto the front under very very hard braking to the point the rear end starts to move side 2 side !
The added bonus is they fill the wheels nicely but make cleaning inside them harder tho.
Posted 28 May 2020 - 07:33 PM
To match the front or look similar? Those rears are so weedyNot sure there is that much point - the rear brakes arn't really doing that much compared to the 8 pot fronts.
Posted 28 May 2020 - 07:55 PM
I’m happy with my standard 4 pots up front, might look at getting some rear drilled brakes from reyland if they are larger, fill my rotor nicely!
Anyone running rs6/rs7 brakes are the rear?
Posted 28 May 2020 - 08:02 PM
Thanks for the reply guys, one is for aesthetics tbh but also for better rear braking performance.
Bobby.
Reyland don't do crossed drilled discs due to the chance of cracking issues.
Dan has the RS7 wavy big rear discs on his 8v.
Posted 28 May 2020 - 08:31 PM
Bobby.
Ahhh! Hmm I wanted the matching crossed drilled.
I see MTec do some but they are standard size.
I’d love to get the wavy discs but I’d have to upgrade my fronts to 8pots just need to find some cheap!
Posted 28 May 2020 - 08:57 PM
I wouldn't go down the wavy disc route on the 8pots as those oem discs are being phased out for normal round one's.
I'm running the 8pots on my 8P but with J hook Reylands.
Posted 28 May 2020 - 09:32 PM
I will be going with the Reyald J hook disks when the time comes. Not sure about the rears unless I wanted the symetry although that day will come long after. Still not sure about the fixed or floating options but will need to look into it nearer the time.
Posted 13 July 2020 - 07:28 AM
I’m going to upgrade my rear discs to the 356mm discs from s7/rs7
have bought some adapters and discs and hopefully trial fitting them the weekend
Posted 13 July 2020 - 08:31 AM
Steve.
If you don't already have them your need these to remove the rear caliper bracket.
Posted 31 July 2020 - 07:14 AM
Finally got round to fitting the vagbremtechnic kit to the rear of my RS3
fitted perfect even tho it said it was for car equipped with electronic handbrake
we will see how the upgrade performs as the pads bed in but they look the part anyway
Posted 31 July 2020 - 08:26 AM
Steve.
The 8P/8v use the same rear discs just the brake calipers/pads which are different mate.
Posted 31 July 2020 - 01:22 PM
Yh vagbremtechnic wasn’t sure if the brackets would work or not with the 8p chassis
but they do so it’s all good
no need to spend best part of £800 on rear discs when this cost me £230 with new s7 discs and Brembo pads
Posted 31 July 2020 - 01:28 PM
Nice... you got a picture?
Posted 31 July 2020 - 01:29 PM
Steve.
Typical VAG different calipers same mounting.... result ! 😂
Posted 03 August 2020 - 08:09 AM
Heres a couple of pics of the upgraded rears
Edited by SteveHealy71, 03 August 2020 - 08:17 AM.
Posted 03 August 2020 - 08:10 AM
Posted 03 August 2020 - 08:27 AM
This should be right now
They look the business!
Have you got the part number for the rear brake discs?
