Sent from my VOG-L09 using Tapatalk
http://cloud.tapatal...0213_094033.mp4
http://cloud.tapatal...0220_130842.mp4
Edited by TurboTed, 20 February 2020 - 11:04 AM.
i am going to just have a stab in the dark here, the car has high miles the noise is coming from passenger side. the noise also sounds like its rubbing on something. dual mass, timing chain guides?
with out taking a look it is a guessing game.
Loose spark plug ?????????
It's not coming from just left side. We just filmed from that side. With the bonnet open you can't pinpoint the exact position. All fans, pulleys etc have been checked. My question is why isn't there an error code (yet) and no change in performance, no oil or water use. Could it be something simpler?? Oh gosh I hope so
I think that's what it is!!! It looks like it's one of the belts.
you said its all be checked and no faults found? if you can narrow the noise down where is it coming from?
If it`s a belt noise then spray WD40 on it with engine running. It will stop instantly for a few seconds then come back again.
Can rings and piston problems make that noise.
Not a chance . Neither can the turbo. Muppets.
Go round various parts of the engine/gearbox with a stethoscope or failing that a long screwdriver put to your ear. You`ll should hear the noise easily enough.
Edited by RS3Dell, 26 February 2020 - 06:24 PM.
