Does any tuner make a Turbo inlet pipe for the PFL ( 367 BHP ) engine similar to the one below from APR for the FL
I too cannot find a turbo inlet pipe (not intake pipe) for the RS3 8V PFL. Anyone?Does any tuner make a Turbo inlet pipe for the PFL ( 367 BHP ) engine similar to the one below from APR for the FL
Sent from my SM-G950F using Tapatalk
Edited by RS3Dell, 19 March 2019 - 01:44 PM.
great.. thank you very much. have been in search for something like this for some time..
are you using it?
rgds
https://www.hperform...intakepipe.html
Not sure if the picture is showing an upgrade intake for the STOCK turbo? The aperture at the bottom looks too big, you cant suddenly magic a larger diameter final intake size (checkout the size of APR one in the pic in the post above) - it would need an adapter to fit. The Forge version for the FL car has several different size adapters for cars with hybrid/big turbo conversions. Worth checking before you buy.
Edited by Fivepotfan, 24 March 2019 - 05:27 PM.
Did you ever go ahead with one? Going by the description its compatible with TC550 or series loaders, translation for stock turbo I believe. Considering giving one a try.
