New brakes
27 replies to this topic
Renga
Renga
  • 149 posts
  • LocationSweden
New Brakes
I need a rear brake upgrade 335mm or 356mm!?
And i think its time to replace my front MTM (PFC) 376mm fronts to, PFC want sell me the replacment disc and told me to contact MTM $$$..
Any suggestions on this uppgrade
Only a little spirited street use no tracktime.
Edited by Renga, 25 September 2018 - 11:46 AM.
The MTM discs are a lot of €€€€€ i would have a look at the UK market for discs tbh.
As for the rear upgrade there's a few over here too which do those kits.
Just do a Google search mate.
Renga
Renga
  • 149 posts
  • LocationSweden
Vagbremtechnic have a 335mm kit with TTRS 8P Rear Caliper Carriers, i have a set of RS6 C5 rotors i can use anyone know what part number the carriers have. Couldn't find that on Google..
https://www.vagbremt...ade-kit-di0013/
The rear conversion adapter kit for the 356mm is 540$, 540$ for two small brakets is to much i think..
https://www.bks-tuni...rs-adapter.html
Renga.
The TTRS bracket part No's are 8J0 615 425 D & 8J0 615 426 D.
Which are the same part No as our 8Ps i think them brackets are required if your using there discs on a non RS3/TTRS car mate.
Renga
Renga
  • 149 posts
  • LocationSweden
OK Then this should fit right?
034Motorsport is proud to offer our 335mm Rear Brake Rotor Upgrade Kit for the 8J Audi TTRS!  This kit is designed to upgrade the factory 1-piece 310mm rotors to larger 2-piece 335mm cross-drilled rotors from the C5 Audi RS6.
https://store.034mot...ttrs-335mm.html
May be not as the TTRS hubs are a different part No to RS3 8Ps one's.🙁
Just check 1st in case I'm wrong mate.🤔
AwesomeLisa
AwesomeLisa
  • 38 posts
  • LocationManchester
Hi,
I know someone has already posted about vagbremtechnic but here is the link to page where you can have a look at all the products theyoffer for your vehicle  :D
www.vagbremtechnic.com/Audi/RS3-8p-2011-2012/
Ridgeracer
Ridgeracer
  • 49 posts
  • LocationNorway
The caliper carriers for the TTRS and RS3 are expensive ! Anyone knows if we can use other carriers ?
Edited by Ridgeracer, 21 July 2021 - 12:33 PM.
An alternative 350mm Reylands.
Attached File  20181224_185815.jpg   36.25K   7 downloads
Ridgeracer
Ridgeracer
  • 49 posts
  • LocationNorway
Im thinking about the carrier that holds the caliper : )
Im going to paint them red and was thinking of buing new ones. They cost more than £ 200 each.
I have the 355mm discs from RB Racing. I like the drilled look.
Ridgeracer
Ridgeracer
  • 49 posts
  • LocationNorway
Just bought calipers from the Maserati Ghibli. Think it will be a nice upgrade from the 4 pots.
SteveHealy71
SteveHealy71
  • 41 posts
New Brakes
I upgraded my rear brakes with these adapters from VBT and I used S7 discs from mtec and retained my original calipers and carriers
the adapters don’t say anything about fitting the 8p chassis but they fit fine with no issues
https://www.vagbremt...3-golf-r-di0019
New Brakes
Steve.
Great bit of info that the VBT adaptors for the later models can also be used on the 8P platform 👍
I helped Dan fit the rear RS7 wavy discs on his 8v using the VBT adaptors without any problems.
The wavy rears look great as they now match the fronts.
SteveHealy71
SteveHealy71
  • 41 posts
mad thing about is that even VBT didn’t even know they fit the 8p chassis, I did tell them
Steve.
VBT 355 recently.
Steve.
Steve.
They probably didn't know as they wasn't marketing them for the 8P even though the standard 310mm rear discs are the same but the rear calipers are not.
Edited by RS3Dell, 23 July 2021 - 10:58 AM.
SK-RS3
SK-RS3
  • 1,756 posts
Just had a shock need to do front pads and rear discs and pads.
What’s the best set up to go for ?
Looked to go to Audi for the lot but £1350 😂
Reyland will sort you out. Top quality stuff.
SK-RS3
As Neil recommended and I've been running at both ends for some years now Reyland are a cost effective replacement also the technical support from Martin is very good,as for brake pads I'm using PBS Prorace in the front with their Protrack in the rear but I do a few trackdays a year and this set up is also fine for road use.
I've run DS2500s and Carbon Lorainne RC5+ pads but the PBSs are my go to pads for my needs and usage.
SK-RS3
SK-RS3
  • 1,756 posts
Was considering ferodo ds2500 pads and vagbremic dics
What pads do Audi use is it brembo ?
