Edited by terminator x, 27 September 2018 - 06:38 PM.
I`ve been googling,it seems swapping the discs over helps but only shortime. Another forum with similar issues has hadHere’s a question
I get squeal going forwards but not in reverse.....
If it’s the ‘grain’ of the metal faces that’s causing my squeal then I wonder if swapping the discs over from left to right and vice versa would essentially mean the discs are running the opposite way to what they were.....
I`ve been googling,it seems swapping the discs over helps but only shortime. Another forum with similar issues has hadgood results changing to grooved discs.They reckon the grooves keep the pads deglazed. Seems to make sense.
Edited by T-800, 28 September 2018 - 07:42 PM.
On a side note, how is everyone keeping the FL OEM disk drilled holes clear of brake dust? The larger ones are fine to attack with a posidrive screwdriver but the small ones are totally solid. Thinking about taking the Black & Decker to them...
Small ones are just dimples not holes.On a side note, how is everyone keeping the FL OEM disk drilled holes clear of brake dust? The larger ones are fine to attack with a posidrive screwdriver but the small ones are totally solid. Thinking about taking the Black & Decker to them...
Edited by T-800, 28 September 2018 - 08:40 PM.
Thanks Sean for the heads up - they would have been holes tomorrow!
Why are they putting dimples into the disks? Inevitable that they would be blocked by dust in the first week. Once filled with compacted brake dust the holes feel flush to the touch so will offer nothing in terms of either cooling or bite.
I didn't have a problem with the larger ones though - most were fairly open and a poke or two with the screwdriver cleared them fully.
Edited by Quattro, 28 September 2018 - 09:04 PM.
Neil there was no real side to side play in the caliper.Sean
Just a thought. I remember reading somewhere that you should never remove the bolts between caliper and the mounting.
Only ever the bolts between the mounting and hub.There is a small amount of play between caliper and mounting so it
could be possible to torque those bolts and the caliper may not be exactly 90* to the disc.That info I read said if
you do remove those caliper / mounting bolts then just nip them up then press the brake to align caliper and only then
torque them up.
I suppose that sounds about right.If it`s aligned bob on then at least you may get equal squeal forwards and backwards.
Edited by T-800, 30 September 2018 - 06:02 AM.
