Fair enough but it is the setup that is expensive not TW afaik.
John.
I believe he don't even make them as that's done by others.....he just puts his name to them & a handling charge on top.
John.
Tough crowdJohn.
Tough crowd
John.
South London housing estate
Neil.
Ferodo Premier by the looks off.
Correct. Fitted tonight and just back from the bedding in
Still squealing albeit no where near like the DS.
This is getting back to the disc material mate
I agree 100% Dell
That was my suspicion after the oem then the DS started going noisy.
Am going to monitor the premier pads over the next few days and see if it calms down or indeed gets worse.
If no improvement I’m going to ditch the OEM discs as a next port of call.
£236Sean.
Sounds like a plandid the premiers set you back much mate ?
Tbh i think the premiers are a much under valued brake pad which would suit 75% of the RS ownership.
£236
Gone up a bit since Brian bought a set at MRC sometime agobut in saying that i found that with the Ferodos baring the 8Ps which you can still get for £40
Here’s a questionI get squeal going forwards but not in reverse.....
If it’s the ‘grain’ of the metal faces that’s causing my squeal then I wonder if swapping the discs over from left to right and vice versa would essentially mean the discs are running the opposite way to what they were.....
