Brake squeak
112 replies to this topic
Quattro
Quattro
  • 416 posts
Mine didn’t come with the shims, he sent them out FOC separately for me. Fitting tomorrow
I can’t recall seeing them in the boxes either but will check when I get home tonight.
I did email Trevor but the automated reply says he’s on holiday until 1st October.
I have a spare brand new set of shims if you are stuck.PM me if interested.
Quattro
Quattro
  • 416 posts
Thanks for the offer
I’ll check my boxes tonight if not I’ll just run it another week until Trevor is back and hopefully get sorted, if all else fails I’ll pm you though
Mine are squeaking full time time now at low speed.
Very high pitched too.
Then don`t go slow.
Oli
Oli
  • 496 posts
I didn’t speak to Trevor - I just rang the office . Fitting tomorrow so will report back
Quattro
Quattro
  • 416 posts
No shims in the boxes either, I’ll ring tomorrow.
Quattro
Quattro
  • 416 posts
Spoke to Peter this morning who said he’d send me some out.
Then got a call back saying he hasn’t got enough to do that!!
Says not sure when they’ll be back in so the wait continues!
Raptor there’s a pm coming your way
Spoke to Peter this morning who said he’d send me some out.Then got a call back saying he hasn’t got enough to do that!!Says not sure when they’ll be back in so the wait continues!Raptor there’s a pm coming your way
Tbh I don't think that will cure the problem & that's providing there's enough clearance to fit them.
The backing shims didn't come on both the Ferodo Premier & DSs I've fitted on both oem & the now fitted Reyland discs.
If they needed them Ferodo would have supplied them with the pads as other brake pads I've use did on motorcycles.
I've never had a noise problem with either off these set ups.
Quattro
Quattro
  • 416 posts
Never had any squealing issues with any other brakes I’ve had, but would like to try the shims to see if it does reduce or eliminate it for me.
Only time will tell
Never had any squealing issues with any other brakes I’ve had, but would like to try the shims to see if it does reduce or eliminate it for me.Only time will tell
Just a note when I 1st got my 8p it had 5k on it & in the cold/damp at low speed it had the squealing many on here have 😖 but after a short time it disappeared never to come back.
I'm just wondering if it's the different way people brake or conditions there RSs are used ? 🤔
Quattro
Quattro
  • 416 posts
Just a note when I 1st got my 8p it had 5k on it & in the cold/damp at low speed it had the squealing many on here have but after a short time it disappeared never to come back.
Mine are silent until warmed up and then it’s low speed.
8V on wavy discs.
Same here
After a few stops they start.
After 1.5k miles all of a sudden they started squeaking
Prior to that the oem pads were silent up to 5K miles then one day started squeaking.
Bonkers bloody cars.
Edited by T-800, 24 September 2018 - 05:06 PM.
8V on wavy discs.
Same here
Very strange.  :89:
It is bloody bonkers. :84:
Must have something to do with the discs as different pads are being used but same problem. :(
Edited by RS3Dell, 24 September 2018 - 06:03 PM.
Very strange. :89:
It’s looking to me anyway like new discs should be the answer.
The pads I’m actually unsure over now.
Unsure the pads are the problem more likely the discs mate. 🤔
I never had an issue on my PFL car Dell
DS pads were great.
DS pads were great.
May be they changed the disc material from the one used on the PFL ? 🤔
Didn't move forward in that dept 🙁
The DSs are very good pads in many areas mate 👍
Maybe Dell
Nonetheless new Fronts should cure the issues hopefully.
The DS were the also the only pad that worked on my 8P
That’s until a certain brake ‘expert’ on here and a know it all on another forum dissed them.
