Tapper them?Pads out and I’m gonna try something
Note the edge of the pads catching on the disc lip
Brake squeak
Posted 19 September 2018 - 07:36 PM
Posted 19 September 2018 - 07:46 PM
Yes mateTapper them?
I’ve done all 8 with a slight chamfer.
Will see tomorrow if it makes a difference.
Posted 19 September 2018 - 09:13 PM
it would make sense from an acoustic perspective, if the non-worn lip of the disk rubbing on the pad, would be at 90 degrees to the pad face, it’s a large disk so imagine if anything was catching on the outer edge, will be more likely to cause a harmonic = sqweek....than on the inner side towards the hub, less leverage and less room for harmonics to be generated.
Maybe you are on to something,
Interesting to know, keep us updated
OMR
Edited by Oldmanracing, 19 September 2018 - 09:15 PM.
Posted 20 September 2018 - 01:07 PM
Get rid of the discs and go for big ass Reyland or Alcon
Am waiting on Brian to report on his 380 mm Discs......
Well after a bit longer wait than expected the Reyland discs have turned up. I have had them made to my spec.....380mm x 34mm, two piece floating with alloy bells, directional cooling vanes and curved grooves.
First impression is that they look good, only disappointment is that they are slightly heavier (11.5kg v 10.6kg) than the same size Alcons I had on my PFL car. I plan to fit them this weekend if the weather behaves itself. The other discs in the pictures are my old Alcons for comparison.
IMG_3694.JPG 70.25K
16 downloads
IMG_3695.JPG 71.25K
15 downloads
IMG_3698.JPG 68.28K
15 downloads
IMG_3699.JPG 133.69K
16 downloads
Posted 20 September 2018 - 01:10 PM
Brian.
Very nice mate👍
Posted 22 September 2018 - 06:08 PM
Posted 22 September 2018 - 06:22 PM
I’ve ordered some Ferodo premier pads to see if they are any better.My Ferodo pads from Trevor have started squealing like hell the last day or two!!
Never had any noise from the DS on my PFL with wavy discs
Can’t understand why the FL is quiet for a while then starts squealing.
Posted 22 September 2018 - 06:41 PM
Mine were silent initially but over the past couple of days a low speed squeal has appeared.I’ve ordered some Ferodo premier pads to see if they are any better.
Brakes are stronger than standard pads but they do create a fair bit of dust!
Posted 22 September 2018 - 07:11 PM
I think my issue is the discs.Mine were silent initially but over the past couple of days a low speed squeal has appeared.
Gonna be changing to the Alcons as soon as I get chance.
Posted 22 September 2018 - 07:24 PM
I’ll just be running them until discs and pads are worn.I think my issue is the discs.
Posted 22 September 2018 - 07:46 PM
Have you got the shims fitted?My Ferodo pads from Trevor have started squealing like hell the last day or two!!
Posted 22 September 2018 - 08:16 PM
Posted 22 September 2018 - 08:33 PM
The shims come separately , not fitted from Trevor.Without them they will squeal.The Ferodo ones that came from Trevor as far as I recall had shims fitted.
Posted 22 September 2018 - 08:52 PM
In that case I don’t have any shims?The shims come separately , not fitted from Trevor.Without them they will squeal.
Are the shims extra from Trevor?
Edited by Quattro, 22 September 2018 - 09:12 PM.
Posted 22 September 2018 - 09:22 PM
They are free from Trevor.In that case I don’t have any shims?
Posted 23 September 2018 - 09:24 AM
Didn’t fit on my FDS1664 ones toooo tight.
Had to wait until worn a bit, although in my case they made bugger all difference.
Edited by T-800, 23 September 2018 - 09:24 AM.
Posted 23 September 2018 - 10:34 AM
Posted 23 September 2018 - 10:41 AM
Yes mate they did. See post #9Sean did they come in the box with the pads?
Don’t remember seeing them.
Edited by T-800, 23 September 2018 - 10:41 AM.
Posted 23 September 2018 - 10:46 AM
Sorry totally missed thatYes mate they did. See post #9
I’ll need to have another look in the boxes tonight.
Posted 23 September 2018 - 01:57 PM
