Haldex oil change RS3 8v
Posted 08 January 2019 - 07:23 PM
Are the Haldex/rear diffs on the 8v prone to failure or is it more likely to be wheel bearing or something else which has a more common drive problem?
Posted 08 January 2019 - 07:25 PM
Posted 08 January 2019 - 07:58 PM
Posted 08 January 2019 - 08:18 PM
Posted 08 January 2019 - 09:00 PM
Posted 08 January 2019 - 09:35 PM
Posted 08 January 2019 - 09:37 PM
start the engine put in D and put a screwdriver on the rear hubs and the diff. You`ll hear straightaway where the
noise is coming from.
Posted 08 January 2019 - 09:47 PM
Posted 08 January 2019 - 10:04 PM
You put your ear to it.Ok great, what does the Screwdriver tell you? Do you feel a vibration? It's going into AwesomeGTI on Friday so we'll get it up in the air to do some further diagnostics then.
Any untoward noise will be amplified and easier to hear.
Think of it like a record stylus.
Posted 09 January 2019 - 12:08 AM
On an old 78 😁
Posted 09 January 2019 - 06:00 PM
Probably only noticeable at speeds 33 and 45 thoughYou put your ear to it.
Posted 12 January 2019 - 07:57 AM
Just to give everyone an update, we have found where the whine is coming from. AwesomeGTI got the car up in the air and with someone in the car running the drive. We discovered an oil leak on the front diff/transfer and it sounds like it has run dry! Nasty sound, I’ll post a video at some point. After they looked the part up they found the its been superseded? I’ve tried looking for other posts on this as this is not the right post for people to check on this problem in future, has anyone experienced similar issues. It’s booked into Audi on Tuesday as it’s still under warranty, thank god. Part is £2k alone
Car is a 2016 model which I’ve had from new, 49k miles with extensive servicing at Awesome.
Edited by MRWOO, 12 January 2019 - 04:40 PM.
