Haldex filter
Posted 13 March 2018 - 04:39 PM
Posted 13 March 2018 - 05:01 PM
Posted 13 March 2018 - 05:04 PM
Posted 13 March 2018 - 06:09 PM
Posted 13 March 2018 - 07:55 PM
Posted 13 March 2018 - 07:56 PM
Posted 13 March 2018 - 09:20 PM
Posted 16 March 2018 - 09:02 PM
Posted 16 March 2018 - 10:26 PM
Posted 08 May 2018 - 08:49 AM
Access & removal off the filter was a F#uker ! 😟
20180505_110758.jpg 29.39K 16 downloads
20180505_104853.jpg 62.65K 15 downloads
20180505_105428.jpg 22.84K 15 downloads
20180505_101336.jpg 52.47K 12 downloads
Edited by RS3Dell, 08 May 2018 - 10:55 AM.
Posted 08 May 2018 - 09:11 AM
At the weekend i changed oil/oil filter & cleaned out the pump strainer which after 30k was very clean unlike others I've heard about.
Dell all the best jobs are f****rs
Posted 08 May 2018 - 10:56 AM
Posted 08 May 2018 - 03:33 PM
Posted 08 May 2018 - 05:42 PM
I’ve borked at doing mine due to access issues so mines in at an independent tomorrow for them to do it. I’m supplying all the parts and I’ll chat with the tech in case they haven’t done one before
Rob.
On a 2 poster its ok but flat on your back under the RS its sh*te but not impossible mate
If you don't have a good pump with a thin hose & a very short 4mm allen key( i cut one down to access the top bolt for the filter ) your be stumped & very stressed out.
Next time i'll be going to the garage Jay uses to do it for me mate.
Edited by RS3Dell, 08 May 2018 - 05:46 PM.
Posted 09 May 2018 - 07:32 AM
Dell how does the filter come out mate? once you get the cap off is just a twist or a pull? or both lol mine was wedged and i was in a rush so i gave up and just changed the oil which looked new. I will do it again properly very soon.
I also made the schoolboy error of dropping the diff oil instead first by accident. freaking bolts are so close together.
Posted 09 May 2018 - 07:59 AM
Vroom.
Getting the filter spacer out was my biggest problem followed by doing up the top allen key due to having surgery 5 weeks ago.
I managed to twist the space to break the sealing affect of the O ring on the spacer.
Then fished out the filter but I also remove the pump to clean the strainer which is fitted to it as that collects a lot of dirt & will kill the pump if it clogs.
I personally think the pump strainer is more important to clean then changing the filter.
Posted 09 May 2018 - 08:08 AM
Just dropped mine off at the garage to do mine with a new filter. I had my pump changed a few years ago but I can guarantee Audi didn’t clean or replace the strainer 🤯
Posted 09 May 2018 - 09:07 AM
At least that was do able once the large L shaped ring spanner was purchased.
The only other thing was you had to unbolt one the haldex to chassis brace pieces which was no hassle.
Edited by T-800, 09 May 2018 - 09:08 AM.
Posted 09 May 2018 - 11:07 AM
Hi Dell, must the strainer be replaced or just cleaned and with what did you clean it with?
Regards
George
Posted 09 May 2018 - 11:27 AM
Regards
George
George
The strainer only comes with the pump & as it's made of plastic you just unscrew the 2 trox headed bolts & carefully clean in some brake/ clutch cleaner.
Edited by RS3Dell, 09 May 2018 - 11:28 AM.
