Greetings,
If I decided to get the servicing done at an independent rather than using a main dealer would this invalidate the warranty? Yes I know it sounds crazy and I probably know the answer already but I’m sure I read somewhere that some independents can Service the car and you can maintain the warranty with the main dealer.
Stu
Warranty & Servicing
Started By
StuRS3
, Jan 12 2018 04:25 PM
3 replies to this topic
Posted 12 January 2018 - 04:25 PM
Posted 12 January 2018 - 05:01 PM
Pretty sure as long as the independent uses OEM parts then your warranty stays intact. That's certainly how it's worked with all the cars I've had, so unless Audi stipulate something different then I wouldn't see an issue.
However some things you need to go to a main dealer for - for example the paint warranty on my car is only valid if it's inspected by a main dealer at the specified intervals.
Edited by SeanB, 12 January 2018 - 05:03 PM.
Dreaming of a Merlin purple RS3 with all the trimmings
Posted 12 January 2018 - 05:03 PM
Posted 12 January 2018 - 05:53 PM
Ok would someone please recommend me a good independent in berkshire ( Just in case
Thanks
Stu
Thanks
Stu
