Updated injectors?
32 replies to this topic
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
That's what I have in mine now & no fitting kit required as they already have the seals fitted.
Ok cheers bud.
Where did you get them from?
Ok cheers bud.
I use TPS & you don't need to buy the repair kits which has the already fitted seals.
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
So everything on the list except the repair kit is required?
Yes from what I can remember as it's been some time since I did the work.
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
Cheers bud
RS3_AL
RS3_AL
  • 42 posts
  • LocationStirling/Scotland
https://www.gumtree....ors-/1375385264
set here, get em send to r tech for a check before fitting
Can’t you just buy a set of uprated aftermarket injectors? A set of 980cc direct replacements are less than £400.
Stu.
If your running the stock turbo on the stock or a remapped ecu those injectors are probably too big for the engine requirements & could cause more problems than there worth tbh.
toosmiles
toosmiles
  • 52 posts
Dell with these injectors,have you done them for future proofing?
ive been told by my tuner to update my injectors prior to tuning on my pfl
533bhp Mk6 Golf R
As mine is remapped I'll took the precaution to fitted the superseded injectors just as your tuner has suggested.
Edited by RS3Dell, 06 February 2021 - 02:14 PM.
Btw I don't believe the PF had the injector issues which befell the 8Ps as the one's I've now fitted are 8v.
You really need to check with your local Audi parts department for that info.
Stu.
Fair point Dell, although what happens when you can have switched mapping and have a low boost map for daily driving?
Stu.
On a single injector set up with bigger injectors on say the 8P/8v platform your need even less injection duration so you may not be able to close them down quick enough on a low boost map.
I don't have enough knowledge to say how the solenoid on the hpfp which is controlled by the ECU would play it's part in this.
The stock 8v injectors are more than enough for a hybrid like TTU510s or TTE 500 when a upgrade hpfp is used.
The twin injector system on the FL means you don't have the problem with too small or too large for what the engine was designed for.
Tbh someone like Ben of TTU would be able to answer your questions in more depth than I can.
Edited by RS3Dell, 07 February 2021 - 12:41 AM.
