Talking to Alex this morning and I'm led to believe the MagRide recalibration he did over the weekend on an RS3 (lowered) has totally transformed the car......
It has indeed. It was my car that Alex did
. I was holding off my review in case the car improved even more. Alex is a ninja of coding
, really nice chap.
The car has H&R Springs 30F/20R drop. I loved them when they were first installed as the suspension prior to it was so crashy. The H&R Springs made the car much more compliant, and softer over the bumps which I really liked.
However, over time I began to notice that it was perhaps getting too soft. Comfort mode had barely much difference to Dynamic for example. Coupled with this the high speed Autobahn driving didn't feel as planted and solid as it should be. This was beginning to grate on me and I began to think about the more expensive MSS Kit upgrade based on the good reviews.
So when I heard there was a Mag Ride calibration that could be done T-800 put me in touch with Alex of Vag Car Coding. We met up this weekend at Donnington. After doing various checks and scans on the car for any issues, he got to work. This involved dialing up to the Audi servers in Germany with his dealer level tool. After taking height measurements he made the adjustments and followed the relevant procedures.
When first driving the car we were unsure of the result as it seemed to have softened up the steering quite a lot. Too much perhaps even, as if the rebound settings weren't correct. We decided to drive the car over a few days and see if the car then adapted to the new settings. On the way home from Donnington the car gradually began to sharpen up and the steering feel improved. So clearly the car needs to adapt to its settings. The high speed control was instantly noticeable. It felt I could continue accelerating to top speed without the skittish kind of feeling at those higher speeds. It just felt planted.
Yesterday I also tested the car on various roads and it felt really good. The hold on the road felt more solid and the control used less effort. Overall comfort in any mode is much improved, especially on the rear shocks. My well known road bump doesn't jar on the rear passenger wheel anymore for example.
A noticeable difference between Comfort mode and Dynamic was also returned to the car. Although I wonder if I would prefer Dynamic to be harder still.
I will report back if the car continues to adapt further. For now I would recommend the procedure to anyone who has lowered their car.
Incidentally, there was a 30mm difference all round from actual height to the OEM configuration, 335mm instead of 365mm. Which poses the question have the H&R springs lowered the car 30mm all round, or was it set incorrectly in the first place. If someone could kindly measure the centre of their alloy wheel, to the top of the wheel arch edges and post it up I'd be most grateful. This will at least tell me what the OEM height setting probably was before I lowered it.
