Which engine oil?
Posted 22 February 2017 - 10:22 AM
Posted 22 February 2017 - 10:58 AM
Posted 22 February 2017 - 01:07 PM
Normal spec is 5w30 iirc
2016 Audi RS3: Panther Black | SS seats | Design Pack | Technology Pack & Connect | Dynamic Pack | Alu Styling Pack | B&O | Sunroof | Privacy Glass | Camera
Mods: APR map | Milltek downpipe | Forge FMIC | R8 Coils | 034 Motorsport Intake | Carbon Engine Covers | H&R springs | Oil Temp | Alarm Beep
Posted 22 February 2017 - 03:23 PM
Posted 22 February 2017 - 06:25 PM
Posted 22 February 2017 - 06:55 PM
Posted 22 February 2017 - 06:59 PM
Posted 22 February 2017 - 10:46 PM
Check the oil temp next time your giving it large & see how it changes ?
The make of oil is a personal preference but as long as it meets the VAG spec you cant go wrong .😊
Edited by RS3Dell, 22 February 2017 - 11:34 PM.
Posted 23 February 2017 - 10:01 AM
I would only use 5/30 - 504/507 spec oil as recommended by VAG,as for running hotter the RS has a bigish oil cooler at the bottom of the front bumper which would come into play when running at high RPMs & high speeds.
The Rad in the front bumper is for Coolant.....
coolant.png 421.41K 20 downloads
The oil cooler is above the Filter housing and has coolant running through it.....
oil cooler.png 532.6K 22 downloads
oil cooler2.png 270.45K 18 downloads
Posted 23 February 2017 - 06:11 PM
Posted 23 February 2017 - 09:43 PM
Whats the one on the other side of the front bumper? Gearbox oil cooling perhaps?
Come on T-800, do your stuff!
Posted 23 February 2017 - 09:54 PM
The above is mk 1 RS 3,Whats the one on the other side of the front bumper? Gearbox oil cooling perhaps?
The mk 2 has 2 one on each side.
Edited by T-800, 23 February 2017 - 09:55 PM.
Posted 23 February 2017 - 10:12 PM
Aaaah, serves right for wandering into the MK1 section
Posted 26 February 2017 - 06:11 PM
Hi mate would i be correct in saying that the aux side rad is being used as an oil cooler as its connected via a water pipe from the oil/water heat exchange on the side of the oil filter mounting housing ?
Most VAG cars have this type of oil/water heat exchanger but not plummed into an aux rad ?
Posted 26 February 2017 - 06:21 PM
To me the 'whole' system is interconnected anyway.....T-800
However the smaller one does look as if it's a 'satellite' off the main Rad that connects onto the Gearbox cooler / Oil Cooler.
Edited by T-800, 26 February 2017 - 06:23 PM.
Posted 26 February 2017 - 06:29 PM
Item 7 is listed as an Oil Cooler in ETKA parts catalog.
Edited by T-800, 26 February 2017 - 06:30 PM.
Posted 26 February 2017 - 06:33 PM
Cheers for that mate i thought it was more than another rad for keeping the engine water temp in check !
Posted 26 February 2017 - 06:37 PM
Posted 26 February 2017 - 07:08 PM
There's 2 off them on the MK 2 Dell.
Posted 26 February 2017 - 08:44 PM
I presume Audi have fitted the 2nd rad to help control any additional heat that the extra BHP the MK2 may generate in the cooling & oil systems ?
In the past ive dumped the VAG oil to water cooler & fitted an Macal oil to air with great success in controlling the engine oil temp
