RS3 8V: One step at a time
535 replies to this topic
#181
deepspacemillar
deepspacemillar
  • 376 posts
Shaunee - you mentioned yonks ago about some handling mods at some point to make it a bit more dynamic. Have you made any of those or any plans to?
#182
rocketer
rocketer
  • 368 posts
  • LocationSweden Stockholm
Just a little demo of how it now sounds on cold start.
I have similar sound but feels louder with Milltek catback because of larger pipes vs sport exhaust. Although I am going for Milltek decats also so little more sound probably? I have also the el mod which is much nicer than just a unplug solution. When I am fedup sometimes in the future I just switch to oem in 2 sec. Climbing around under the car doesn't feel so nice.
#183
TBH I find the car fine in the handling department for road use.  I really doubt I'll bother look into that area now.... depends what comes up.
#184
Josh Williams
Josh Williams
  • 23 posts
Have disconnected my valves whilst fitting H&R's last weekend and so far love it.
Just wish there was a solution to maybe have the valves open constantly whilst being able to manually shut them whilst on motorway journeys!
#185
rocketer
rocketer
  • 368 posts
It has been written a lots of times that there is a mod and it cost about 1£ and maybe 1/2 an hour to do as simpel as that.
#186
Tell me more!!!!
#187
rocketer
rocketer
  • 368 posts
Tell me more!!!!
Really? I am not by no mening disrespectful but the el mod cutting these exhaust flaps was already on the 8P? It's a simple electric switch which you place where you open the bonnet at least on our right side driven cars. Then you cut the power on the exhaust flaps when they are in sport mode so they stay open. When you want it silent you just flip the 1£ switch so the power is on again to comfort and the car is silent again. It can of course be that it was only in another forum audisportnet? I have the link from there but don't know if its ok to put it here? What do you think?
#188
micloi
micloi
  • 20 posts
Remote controlled version of the mod for the S3. Could create something similar for the RS3?
http://www.awe-tunin...-exhaust-remote
#189
rocketer
rocketer
  • 368 posts
http://www.audi-spor...-valves.265123/ here it is, if its ok? Cheap and working fine :).
#190
Josh Williams
Josh Williams
  • 23 posts
Looks like a little project for the christmas break that does!
#191
Am I missing something here lads ,,,,,,,, there is already a button on the dash that does the same thing ????
#192
mrAudi
mrAudi
  • 2,079 posts
  • LocationSE England
What.......apart from your marbles
#193
rocketer
rocketer
  • 368 posts
Depending on what you want :)? This is for those who wants to keep the flaps open all the time for more sound and quiet when you want. Probably similar thing to S7 or other RS/S models with electric controlled exhaust flaps.
#194
Dynamic turns on the noise of course although it still goes a bit quieter between idle and 3k. The switch mod is for the true nutters ;)
Unfortunately the valves are still opening and closing dependant upon gear and revs when in Dynamic mode.
"Chav Mode" is only available by keeping the valves open by other means.
#196
I might have a look into that.  Thanks.
#197
Zoeben
Zoeben
  • 31 posts
Enjoyed the thread, we seem to have a lot in common Shaunee, and not just the colour. Have you not tried the quick release number plate brackets that came with the forge intercooler? It's always nice to compare figures after making the same or similar mods.
I never intended playing with mine until I read Aoon's thread, ( the car ) now not sure where I'm going to stop.
Thanks for taking the time and looking forward to the next instalment
#198
I have the quick release number plate bracket. I'm now plateless
#199
Yes... the insert assumes you'll be using the stock bolt.
Yes... torqued the nut up, but I can't remember the amount.  It's stated in the fitting instructions. :)
Shaun,
Any update on the fitting of the dogbone? Has it made any discernible difference or caused any extra vibration/knocking (other than what you previously mentioned in your earlier post)
#200
I don't remember seeing those in the kit..... It's not really a problem now as the plate is relocated.  I may give them a bell though to get a set sent through.
Glad to the thread is of some use! :)
