Audi RS3 8p Brake Problems
137 replies to this topic
Chr1sB
Chr1sB
  • 63 posts
I have new front disks and the Redstuff pads on .. but the droning when braking is horrendous. Am thinking about going back to the original pads but am just wondering whether anything else could be causing the issue. Any thoughts anyone ?
Couple of things:-
Did you bed them in properly from day 1?
Have you tried doing the bed in procedure again (half way through the pads life)?
I find a series of hard braking applications tends to sort the drone out for a while but again I'd rather put up with drone than a vibrating and squeaky combo
Edited by JayRS3, 06 February 2017 - 10:09 AM.
Chr1sB
Chr1sB
  • 63 posts
Couple of things:-
Thanks for the suggestion- I'll give it a try ... thanks
Has anyone heard or used these front discs by compbrake they are handed & seem to be keanly priced !
They also do maching rears which are also handed  :)
http://www.compbrake...ellrotor-combo/
I also have the Redstuff pads.Trust me after correct bedding in they will drone for about 2 days.Then it just stops of it`s own accord.
SK-RS3
SK-RS3
  • 1,756 posts
I haven't got red stuff but have had continuousl droning from the passenger side for the last 12 years nothing seems to fix it !!
Divorce or turning up the radio 😂
Ive had none of the probs others have had ! new OEM pads on new OEM discs no probs but changed to EBC redstuff at 10k due to the wear rate off OEM pads on the discs still no probs !  :)
Earplug just in left ear??
Take out the passenger seat.
Silence.....
SK-RS3
SK-RS3
  • 1,756 posts
I've tried opening the door ( while moving ), the window the lot nothing works think might need some of those noise cancelling headphones
SK-RS3
SK-RS3
  • 1,756 posts
With brake fade is it due to the pads or discs or combo of both .
Car was recently serviced at Audi and they never flagged up need for new discs which in my eyes means there's life left in them or surely Audi would of tried to flog me some new ones.
But under heavy breaking starts of strong and then fades away. ( OEM discs and ebc yellowstuff pads )
Just wondering if just changing pads would solve this or do what some have done and changed discs and pads
David8
David8
  • 431 posts
  • LocationBournemouth
Have no idea why but I'm still getting steering wobble when braking at high speed and at times at about 30 to 40 mph I have replaced the oem discs like for like, with red stuff pads using the correct bedding in procedure , refurbed the wheels, new tyres ! All front suspension parts replaced new bushes etc , so I'm at a loss to what it can be the only parts that have not been replaced on the brakes are the calipers??
David
A question.....
If you clean the discs (wheel cleaner then jet wash) does it disappear ?
I used to get this when I used redstuff but it went away after cleaning.
Then came back after a few days good driving.
Also has a wheel weight fallen off? When I had new tyres fitted one fell off and instantly you notice it.
Have you're wheels been road force balanced ?
David8
David8
  • 431 posts
Ok, I had the wheels hunter balanced and all checked out fine last week as found a nail in one of the rears after it came back from specialist they said front drivers side had a very slight buckle but all balanced up fine,
The car does need a clean so I will give it a good going over at the weekend and clean holes out in the discs and test it and see what happens , I'm happy to say that's the only issue I have ! Thanks guys
Was it a Hunter road force balancer and did they match the wheels to the corners of the car?
David8
David8
  • 431 posts
As far as I know it is, not sure about matching the corners what do you mean by that a wheel alignment ?
No not wheel alignment ,if used properly the Hunter road force balancer can determine which corner is best to fit each wheel to get best results.
