Have one side done so far
Just remove disc and caliper, and bolt new disc and caliper bracket back on - the kit is supplied with all bolts and the rub ring to fit on back of rotor
You don't have to remove the brake shields, they just clear the back of the disc, but it's only by a couple mm and you could get rocks lodged between disc and backing plate
But I have chosen to remove the backing plates on all 4 corners to get better cooling - I don't drive on gravel or snow
Edited by domino, 08 July 2016 - 02:22 AM.
