For me it's to cure another issue I have with the Redstuff.
Whats issues have you had with redstuff Mate?
I have some and was going to fit next month.
Ibis RS3 - Buckets - Bose - Black Ed - Cruise - High Beam Ass - Privacy - Elec Mirrors - Heated Rear Seats - Light & Rain Pack
VW California GP 180 DSG - "Candy"!
My car has started making the noise again now
It is over 3 years old but i have the 4yr extended warranty on it and it only has 13000 miles on the clock is it worth me even trying and having to listen to Audi's sh1t again??
I have two dealers here in Kent who point blank refuse to change anything I have even gone through Audi uk
the dealers just keep the car for a few days and report "its all ok" ! ???
Edited by Paul, 09 March 2015 - 06:21 PM.
Be interested to get your comments on Yellowstuffs Veneeringman as mine are due to be fitted on the 24th.
Just reviving this thread with an update on my experience using of EBC Redstuff pads for prolonged daily use.
Well after using the Reds for 21K miles on new discs its like chalk & cheese in comparison to the original Audi/ Pagid pads. No squealing, no pad deposits, excellent consistent wear on the discs and a fairly low wear rate.
Knowing the pads were getting pretty low I found the dust deposit increased dramatically and I was getting a rumbling during heavy braking. However after replacing the pads today I found the bracket on the strut that holds the brake line & wear sensor cable on the N/S was loose so that could have been resonating. Since fitting new pads it's gone so I can't really confirm if it was the pads or not.
I believe in getting my moneys worth
IMG_0025.JPG 66.03K 10 downloads
New pad in comparison
IMG_0042.JPG 78.09K 10 downloads
N/S pads appear have worn more
IMG_0039.JPG 67.36K 10 downloads
O/S for comparison
IMG_0041.JPG 72.45K 10 downloads
Disc still in excellent condition, low wear and surface mirror smooth
IMG_0028.JPG 45.16K 9 downloads
IMG_0035.JPG 26.25K 9 downloads
Knackered disc with Audi pads after 26K miles as comparison
IMG_0283.JPG 64.21K 9 downloads
New Red's fitted and bedded in today. Looking at the condition of my discs I see no reason why I wont get another 20+K miles out of them.
Standard 4 pot calipers Rick. I find they are fine for my fast road use with the Red's.
Considered the 8 pots although I can't justify the cost considering I don't have any brake issues with the setup I have already.
I couldn't agree more Duke3D, these redstuff are awesome. And it pleases me that you've had over 20k miles on a set, id be really chuffed at that. For the money £170 for all round front and rear brakes you can't knock it at all.Just reviving this thread with an update on my experience using of EBC Redstuff pads for prolonged daily use.
O/S for comparison
Edited by JayRS3, 07 August 2016 - 09:51 PM.
Well fingers crossed I have the same results as you. Will get them fitted within the next few weeks. What did you do for the bedding in procedure? I will be having all new red stuff pads, genuine disks, 8 pot calipers and all new brake fluid.
There are full bedding in processes on the forum if you search but I do this:
Keep the speed low and do very light braking until you can get to a quiet national speed limit A road, definitely don't bring the car to a stop and hold it on the brakes. On the A road do repeated (10 times) 60 - 20 MPH slow downs with increasing pressure. Let the brakes cool off whilst still driving (10 mins) then do another 10 slow downs 60 - 20 increasing the pressure each time. An A road with a long straight between 2* roundabout is great for this in light late evening traffic. After that I do a few more slow downs on the way home but then keep off the brakes (as best you can ) for 10 mins before I get home to let them cool off a bit. Just avoid bringing the car to a full stop under heavy braking and don't hold the car on the brakes with hot discs.
The Red's have a bedding in surface so they are pretty easy to bed in. After that the next day I am fairly sympathetic with the brake pedal but do the odd increased pedal stab to make sure they still bite. After that normal braking as required.
i have just put new discs and red stuff pads on (after having yellow stuffs on the old discs) i bed them in as per procedure.
The brakes on the RS3 are by far the worst i have had on any 'performance car' I am quite hard on the brakes with a car. After 500 / 600 miles i found on hard braking its suffering from deposit build up and caused vibration. The pads overheated causing me to be massively hard on the pedal to bring the car to a stop. I slated the yellow stuffs and changed to red stuffs as the dust was too much and i felt the were slightly hard but my god its like night and day. The red stuffs are in my opinion not up to the task for fast road driving i know some of you will disagree.
I know the car is not the lightest but getting it to stop after fast road use is not ideal. I came from a b7 RS4 and i felt the brakes on this where unbelievably good for its size.
I also understand the increase in power will not help but i will be seeking an upgrade on the brakes before anything else i think to be honest.
stage 2 8p 445BHP 518lb ft
