Stock Power Performance Benchmarking
Whilst this piece of benchmark data will be quite specific, it will give a baseline for where the car is at the moment in its stock state. As I progress I will be gaining more data, not just from the drag strip, but also from getting VBOX logs for acceleration and in-gear performance. I have a lot of data from my previous A45 (which will be a good comparison), together with other RS3 data I have from a REVO tuned Stage 1 and MRC Stage 3 car. I’ll be overlaying and all sorts, so this will be interesting moving forward. Of course I’ll also gather dyno information as I progress… again, I can overlay this data against my A45 for comparison.
Shakespeare County Raceway
So three weeks back, after running the car in (just over 1k on the clock), I ventured down to Shakespeare to see what my stock car would do. Obviously the engine would still be fairly tight, but I needed to get some baseline data in.
As they say….. The bullshit stops when the flag drops. You’ll hear me repeat that quite a few times throughout this project thread!
I haven’t had the car on the weighbridge yet (will do though) but it is pretty highly spec’d, at least in regards to the “added weight” options! Lol Good for the gadgets…. Not so great for acceleration.
I personally prefer Shakespeare as it’s normally quieter than the Pod…. this day was no exception.
It was a warm day, circa 24degs and little to no wind. The downside was that the track had not been used in a few weeks and it had been raining the day before. Surface prep is key at these places.
I don't really like running early on, especially when no events were the previous day. You tend to find the start line will be a tad "waxy" until some rubber goes down and the track heat starts to build up a bit.
I understand that the RS3 suffers with intercooler issues in warm weather (the A45 charge cooler was unbelievably efficient and effective), so to some degree I wasn’t expecting the car to perform it’s best.
After signing on you need to get your car scrutineered. Not something you need to do at Santa Pod. The rules are the rules though! Lol Thankfully being a new car, it didn’t take long. The scrutineers laughed when they found out how many miles were on it.
Once scrutineered you’re given a running number, which is painted (don’t worry it comes off) on your back screen. Well, they gotta know which car to log the times against.
It was a shame I didn’t arrive a couple of minutes earlier…. I could have bagged “A3” as my number!!!!
So with the car ready, I went down to the “fire up lane” in readiness for my virgin run in the RS3.
Yes… I was first in line.
First run 12.22 @ 111.94mph
Believe it or not this was the first time I had actually launched the RS3. I was a bit nervous I was going to balls it up, but unlike the A45 LC, the RS3 is so much easier to set-up. And unlike my A45, the RS3 just gripped and went like a stabbed rate off the line. Christ the LC on the RS3 is smooth…. Like so smooth. The gearbox as well is a country mile better than the Mercs on the strip. The whole run just went ahead with no drama….. It felt good, which the time and terminal speed showed. This is pretty damn quick for a stock hatchback.
Second run 12.24 @ 110.50mph
Felt just as good as the first run….. How’s the time for consistency. Lol Not sure why the trap speed had decreased… could have been heat soak perhaps.
Now normally I’d be getting really anal and checking / playing with tyre pressures (lowering pressures can aid launch grip), but since this car just launched with no wheel spin or axle tramp, I really didn’t see the need to faff around with anything. The 60ft times back that up with a good 1.79s and 1.80s respectively.
Quite abnormal for me I decided at this point to hand in the gloves. I was happy with those times with a stock car, and as they were so close on both runs, I didn’t think there was much point in further runs. In reality I should have parked the car up and ran later on in the day, once more rubber had been put down…. It may have helped.
Santa Pod
This weekend I decided to take the car down the strip again….. Just for a bit of fun of course! This time though I was going to use the UK’s de facto drag strip. Santa Pod.
The reason for going in reality was I wanted to see if I could better the previous 12.2 and also try a different launch technique to see if I could bring the 60ft time down. Improving the 60ft time can have a dramatic affect on the ET’s.
Luckily the day was dry, sunny but was once again warm. Certainly felt warmer than the 25deg ambient suggested. The event was pretty busy as well. Not great and something I don’t really like about the Pod…. it tends to get very busy, which means you spend a lot of time queuing for your next run. Not ideal by any stretch.
I actually didn’t arrive until lunch time, but I had already heard via whatsapp that the track appeared to be running slower than normal (based on the times that other guys were getting - not in RS3’s mind). There was also a cross wind…. again pretty normal for the Pod.
First run 12.53 @ 108.73
For the first run I launched as I had previously as Shakespeare, using Sports mode on the ESC. It felt good and smooth….. Until I saw my timing slip. Christ that wasn’t good at all. Lol 60ft wasn’t brilliant at 1.82s, but certainly nothing that made me think that was the reason for the slower ET.
Second run 12.44 @ 109.65
Due to the amount of cars running and I did rejoin the queue straight away, I had to wait nearly an hour for the next run. I forgot to take my OBD logger with me, but my charge inlet temps must have been sky high.
This time I tried launching with the ESC OFF.
As soon as the car launched it lit the front tyres up and I had slight axle tramp. Because of this I thought the run was not as good, but it certainly bettered the previous run. The 60ft time had dropped to a good 1.75s, which was where I really wanted to be.
Third run 12.34 @ 111.25
Again, well over another hour had passed before getting my third run in.
For this run I went back to the ESC in Sports Mode, just to see what would happen to the 60ft. It went back up to 1.83, but the overall run was quicker and with a better trap speed. Not sure if the track was starting to improve or what.
Anyway… it was now just before 4pm and I didn’t think there was much more reason to carry on, so I called it a day.
Of course I was hoping I could achieve a better time overall at either event, but all things considered it’s bloody quick for a stock hatchback. As a comparison my previous A45 was no quicker down the strip when it had a Tuning Box fitted (running 12.2s). Stock, the A45 runs around a 12.7s quarter.
At the end of the day this provides a baseline…… future times will be a good comparison.
I hope to be back down the strip in September once I’ve added the first round of mods.
